My point of this and the higher efficiency LED H4 drop ins was to get around wiring in relays to keep it simple, and still take the load off the wires with less of an amp draw. The relays were great with stockers and halogens, notsomuch with LEDs.What you REALLY need to do is to upgrade the system. You'd probably be happy with good old silverline headlights after the system upgrade. headlight relays
I guess my point is the leds look like *** in a classic car. Personal opinion. I don't like the led light either. Halogen I like.My point of this and the higher efficiency LED H4 drop ins was to get around wiring in relays to keep it simple, and still take the load off the wires with less of an amp draw. The relays were great with stockers and halogens, notsomuch with LEDs.
Ok, I get that. I think the LED googly eyes ones look like *** too. This is why I bought Hella H4 replacement lights that look like sealed beams with removable replaceable 55W/65W halogen H4 bulbs, and I was looking into using LED H4 bulbs inside the Hella lenses so it doesnt look like ***. Note the pix below. The lenses are Hella with replaceable halogen H4 bulb cartridges. The pic #2 is the LED H4 cartridges. This way you get the efficiency of the LED bulbs, and the old skool lamp look. Light shown in 3rd pic is a Hella H4 halogen with removable H4 cartridge bulb. It's a damn good looking lamp. Looks like a sealed beam.I guess my point is the leds look like *** in a classic car. Personal opinion. I don't like the led light either. Halogen I like.
I decided to pick up the ones I had showed pix of. The Hella H4 55W65 halogen bulb showed 3/4 of a volt drop measured with a craftsman volt/ohm meter at the light itself, and had the usual heat radiating off it.The LED H4 showed no measurable voltage drop with the same meter hooked up, and no huge amount of heat radiating off it. The LED beam seemed a little brighter than the halogen and about the same pattern when pointed at the shop door.
