slant six,
I notice you are based in Canada. by what standard are making your judgments?
By the US + Canadian (substantially identical) and internationalized European ECE standards that govern the design and safety performance of car lighting equipment all over the world. Most state vehicle codes are hideously outdated messes full of language not applicable to lighting devices made in the last four or five decades (or more), and not even slightly adequate to assure safety; compliance with state codes only means the car's equipment is legal, not that it is necessarily adequately safe.
I happen to live in Texas
Texas is one of the states that has a vehicle equipment code that is at least partially reasonably coherent. The
TX vehicle inspection manual (PDF) says in section 15.10 "Any lighting device, lens and/or reflector used on a vehicle must meet standards adopted by the Texas Department of Public Safety for that particular use," and section 20.29(5)c says to reject turn signals that are "not of a type meeting Department standards" (the same language is repeated in the sections for other lights…brake lights, etc.). The phrases "Department standards" and "standards adopted by the Texas Department of Public Safety" refer to Texas law
requirement for all lighting devices to comply with US Federal Motor Vehicle Safety Standard 108, which specifies in detail all aspects of the design, construction, and performance of all automotive lights and reflective devices. The illuminated area requirements, intensity requirements, color requirements, etc. that you aren't finding in the TX code itself aren't there because the TX code refers to the Federal regulation, which
does contain all those requirements.
OH by the way in all of your expertise you did not pick up on the act that the front signals were red, which is specifically prohibited by the Texas code.
Yeah, I did, just didn't squawk about it. I figured either your camera's color rendering of lit lights was about average (tough to discern red vs. amber) or you were playin' around with lighting setups and hadn't yet finalized.
Im willing to place a LARGE wager that when I finish the car, it will pass the state required inspection without any problems
A wager? That's silly. We're talking about whether your car is legal (no) and safe (no), not whether you can manage to get it past inspection one way or another (no, if the inspector follows the manual).
