Can any body ID these calipers for sure? Both the same, Lefts or Rights?
Just checked mine the bleed screws are outboard on both.
Why would they have the bleeder on the outboard side, you’d have to remove the wheel whenever you bled the brakes, no? .
I think Dana67Dart is right these are 2 right side calipers im going to check manual for information on thesePhoto post 6 is correct.
Mounting ears go inside, bleeder goes outside and up making both calipers right side.
Now if one was to machine the other end of the casting from the bleeder for a bleeder it could be either side.
Yea, bleeder should be up and accessible from the inboard,
good luck with thati think your right bleeders would be accessible if mounted inboard. im going to see if the service manual can help. I want to order 2 more to have 2 sets but dont know what to order R or L?
