Lets see your exhaust tips
skep419
5.9 Magnum 4 speed afficionado
Minesoooota
Currently have exhaust dumping before rear end. Have until Tuesday to make up my mind. Leaning towards having turndowns that are tucked up by the bumper and turn down. Lets see what everyone has.
like this but spaced further apart
Here is some turn down behind the bumper and can see them just barely pokin out the bottom They are usually perpendicular to the ground but had to rob the muffler hangers off for another project
Also had it mounted on the Dart for a short while but found Duster exhaust wont work on the longer wheelbase Dart without a lot of interference
Not on my Dart yet,but soon !!!Only difference is the Red is Black !
Here's mine...made by "Pypes"
I love seeing a big set of sewer pipes stickin' out the back.
I like them narrow like you have them with no tips. Wouldn't change a thing.
Before and after mini tub the tips were re-installed at the correct angle and distance from the bumper.
All after market tips I see have to long of an L bracket that need to be shortened for a-bodies. They all come through with b-body L's which let them hang to low.
These are the correct distance from the bumper in the pics. Some cars I see the tips look as if the are used for wheelie bars.
I had to narrow the fuel tank to reuse the tail pipes . These are still hooked into the turn downs under the car so it appears and sounds like the exhaust flows through them. Yes some exhaust does flow through them. The car has 2 inch to 3 1/2 exhaust H pipe with 2 1/4 tailpipes.
This exhaust with tips still allows allows 8500 to 9000 rpm's with 456 gears and a 5500 converter.
Those SuperTrapps lokk awesome,how do they sound ? I was tempted to go that route,then changed my mind mid stream !!
They are awesome, have had them on this vehicle since the late 80's and I could not have made a better choice. Sound is adjustable and so is the power range so to speak
..was going with turn downs on my '70 Duster but when you start it up... you dust everybody and their cars and they are not very happy.
My "74 Dart Sport.
relocated springs, mini tub, power dumps
My 66's aftermarket stainless tips.
