doogievlg
I want to order new linkage for my Holley 4779 DP and wanted to see some other set ups to get an idea of what would look best and here about any problems people ran into with which brands.
Hey Doogie, is your transmission still using the TV set up? If so I’d recommend the Bouchillon trans cable and brackets. Little pricey but it works and is a pretty stout set up. It alleviates the issues with taller intakes etc. I look at what a transmission cost vs having a setup that operates as it should.
ACCELERATOR CABLE MOUNTING BRACKET 4 BRL - Bouchillon Performance Engineering
BPE TorqueFlite Kickdown Cable Kit - Bouchillon Performance Engineering
I had to modify that bracket to fit at all. The issue I had was not having WOP when flooring the pedal.I had an issue with the carb bracket wiggling on the mount. I made a piece out of flat 1/8” steel that comes off the rear manifold carb stud on passenger side that comes across to the bracket and mounts that eliminated that movement. If that’s what your dealing with.
This is the same setup I have on 2 vehicles and while it does have some quirks, it’s hard to beat for a non factory intake, carb setup.Hey Doogie, is your transmission still using the TV set up? If so I’d recommend the Bouchillon trans cable and brackets. Little pricey but it works and is a pretty stout set up. It alleviates the issues with taller intakes etc. I look at what a transmission cost vs having a setup that operates as it should.
