Looks like that may be a good choice for me also
That is what I have, do they still make them?mcloed sells a b&b clutch with long clutch fingers they work the best, way better than a b&b clutch, just food for thought
Is 1800 enough for a street 340 in a Barracuda? What rate is the sweet spot?i checked mcloeds site, they list that clutch, it's 1800 base 10.5 dia. thing is, they are a very good clutch, i ran them for years in my race car, and put them in customers cars.
What Hayes pressure plate is it? A 3100#? I can't imagine a standard 11" scalloped or 10-1/2" with the OC spring assist that taxing on a leg. Have you checked your pedal to release bearing component condition?...........I have a hayes clutch and man does it kill my leg. Stiff is an understatement.
I have a 10.95 Borg & Beck Long pressure plate with c/w levers, but have not run it yet. I was thinking a good 10.5 would be nicer, just not sure since I am used to Borg & Beck pressure plates. One 10.95 B & B with enough pressure to burst the Z-Bar tube on the 64 Barracuda. The new 10.5 Borg & Beck Long does not have c/w levers. What is your feeling about running the 1800 lb B&B Long on the street?mcloeds were at 2400 lbs had a friend with one, he installed my 1400 lbs in car , it ran two tenths quicker, did not slip 1800 lbs is about the minimum i would run, i used a 1400 lbs in my 340 duster, for years, it weighed 3370 just food for thought. does yours have c/w levers ? btw, his was a 360, dart, full dresser , ran 12.20 in quarter mile.
This is what I’m going with behind a 383, still being installed but it was recommended by Brewers for a good street clutch.
McLeod Racing 75109 McLeod StreetPro Clutch Kits | Summit Racing
the adjustable clutch is a long style, refered to as a softloc style.
