Mopar92
There was a Demon at Carlisle this year that had a Crown Vic cradle in his. Didn't look butchered. Got coilovers, sway bar and everything to work. Pretty nice looking donor idea.
Check out the screen shot from the '72 Plymouth service manual I attached. I, too, have never heard of there being a difference between 2dr and 4dr A-body cars just the disc vs drum width. I'm just assuming that the manual is incorrect.I have heard that drum brake cars have a narrower track width than disc brake cars. But I've never heard anything involving 2 vs 4 doors. gonna have to look into that one
Looking at how the factory Lexus coil springs and shocks mount, it looks to me it would take some some extensive surgery to the inner fenders plus would still require something like HDK's shock hoop supports for added strength. The shock/coilover setup in post #7 is an aftermarket setup and would definitely add to the cost but probably would be easier (less cutting of inner fender) to fit in an A-body.As for the Lexus coilover mounting issue, I think there are already methods to solve that problem:
[SOLD] - HemiDenny Shock Hoop support bars
Anyway, it's an idea. Brainstorming 101. Gotta keep the Banker happy!
Greg
Outside to outside measurement doesn't mean a whole lot as changing rims can change that spec. These are high offset wheel type front ends unlike our factory zero offset front ends. What is most important is track width so that we don't screw up the scrub radius too much from what it was designed for. The stock track width on the '03-'04 CV front is 63.4". Compared to Dukeboys supplied spec of 59.2" ('72 manual says 59.7"), that's a 4.2" (3.7") difference. That 4.2" (3.7") would need to be removed from the cradle and rack. That's where the CV front end gets out of the DIY aspect for most as you need to be able to weld aluminum and properly shorten the internal shaft of the rack.Another old pic I saved from the web. I agree the Crown Vic IFS is a good setup, but it's wide. The pic shows the outside tire to outside tire measurement.
I love it when people grumble about something as simple as wheel bolt pattern with swaps like this. lol
You're probably correct. I was just pointing out what the 1972 Plymouth service manual stated. It doesn't point out a difference between disc or drums just 2 vs 4 door. Go figure.The track width difference isn't a 2-door to 4-door thing. It's a '67-'72 drums or KH disks compared to '73+ disks thing. From a factory TSB...
Our A-body's may not be a true zero offset but, for most practical purposes, they are considered as such. I know that doesn't mean squat in a technical discussion but it's just how they have been looked at over the decades and rims have been used accordingly. I know as long as you don't deviate too much from the factory track width with the rim/tire combo it shouldn't affect the scrub radius too drastically and the negative handling effects that come with it.A few other thoughts. Our A-body's are NOT best served by zero offset front rims. Even most of the factory rims have a +6 offset, not zero. If you want much wider than factory width tires, well, the 18x9's on my Duster are +27 and that's with the '73+ width. So, adding a few inches is a big deal, if you go past +50 for a wheel offset you're going to have a hard time finding rims. And what's the point of adding an allegedly better handling suspension if you can't match it up with a set of giant front tires to actually keep the whole mess on the ground?
Possibly correct but no one will ever know unless someone tries it. It could be great or it could suck. I know there are a lot of things that need to be considered such as the ride height, track width, the angle (if any) of how the cradle was mounted in it's OEM vehicle, possible strengthening/clearancing of the chassis, engine mounts, connecting the factory column to the Lexus or CV front end, etc., etc. However, that's what hot rodding has been about since it started, trial an error. Seems like most people nowadays just wants to buy bolt-ons and doesn't want to, or doesn't have the skills, to research things and fabricate/modify things themselves. <sigh>I'm not against hot rodding or anything, I've done my share. But just because the SC400 is a good set up doesn't mean it will still work well when it's been modified to fit an A-body, or that an A-body will work well with SC400 suspension. There's a whole lot of engineering that went into both, and if you want to put them together and still have it work well it will take a whole lot more.
There's nothing unique about the 4 door suspension. They had the same brake options as the 2 door cars. Sure, it's the track width that's listed and that depends on the tires too, but again, there weren't any unique tire or wheel options available on the 4 doors that you couldn't get on a 2 door. Maybe they spec'd the base option which had a different package. As far as the manual goes, it may also be worth noting that you're not looking at an original 1972 manual. That's a PDF, so depending on how it was created it may be different than the original. This is a scan from the '71 dealer book, notice how it shows 2 and 4 doors with the same track. Of course, it also show's the Demon's with a .1" wider track. That may have been a difference in the base option rims or tires. At any rate, any track width difference comes from the brake or wheel options, the chassis and suspension are the same.You're probably correct. I was just pointing out what the 1972 Plymouth service manual stated. It doesn't point out a difference between disc or drums just 2 vs 4 door. Go figure.
Finding rims to work is not an issue for the Lexus or CV front. There are literally a few hundred styles/sizes available to fit. The real issue is getting a rim that will also work on the rear that matches the front high offset without using a longer rear axle, spacers, custom built rims, or some combination of the three. Of course, going with off the shelf classically styled muscle car rims is practically not an option.
I've been considering the b body 8.75 for the same reason, did you run it stock or cut it some?There's nothing unique about the 4 door suspension. They had the same brake options as the 2 door cars. Sure, it's the track width that's listed and that depends on the tires too, but again, there weren't any unique tire or wheel options available on the 4 doors that you couldn't get on a 2 door. Maybe they spec'd the base option which had a different package. As far as the manual goes, it may also be worth noting that you're not looking at an original 1972 manual. That's a PDF, so depending on how it was created it may be different than the original. This is a scan from the '71 dealer book, notice how it shows 2 and 4 doors with the same track. Of course, it also show's the Demon's with a .1" wider track. That may have been a difference in the base option rims or tires. At any rate, any track width difference comes from the brake or wheel options, the chassis and suspension are the same.
Here's the problem. It's not about finding rims to fit the Lexus front suspension. You're right, there are tons. It's about finding rims that fit the Lexus suspension that ALSO fit inside the fenders on an A-body. I measured the front end of my car as in the first few pictures, outside edge of the tire to outside edge. Now, that's a really rough measurement, but it's something. I got 69", just like for the SC400 front end. But, here's the thing, my car has no extra room to the outside. So, whatever that SC400 has on it, that's as wide as you can go to the outside. If it's got +50 offset rims (like the factory rims for that car), you're not going to be able to do much to add tire width because anything extra you add has to be on the inside, so more offset. I'm not sure what tires are pictured, they look like they could be fairly stock which would mean 225's. If that's the case, and they're 225's with a +50 offset, even going to a 245 would mean a +70 offset rim. Not going to find a lot of those. The math says about the same. The track width of the 73+ cars is 59.15", plus the rim offset (+6) because the track width includes the rim offset, so the hub to hub should be ~59.6". The SC400 track width is 59.9", which is almost the same, but that's with a +50mm offset factory rim. So, the hub to hub is more like 63.8". That's a 2.1" difference on each side, so, 53.8mm wider on each side than a 73+ set up. On my Duster I run 18x9's with 275's and an effective offset of +27. That means to run the same wheels and tires with an SC400 front suspension my rims would need to have an offset of +80.8. Not going to find those either.
And the A-bodies already have the front to rear offset mismatch straight from the factory if you want to run wide tires. That's why I have a 68-70 B body 8 3/4 in my Duster. If I ran a A-body 8 3/4 with BBP axles my rear offset would need to be +9mm with the 18x10's and 295's that I run, compared to the +27mm offset I have up front. As it is with the B body 8 3/4, my rims are +38 in the back and +35 in the front (the +27 comes from a 3mm spacer and Dr. Diff's 13" rotors that add 5mm compared to the 73+ disks). And really I could use +35 front and rear with the 3mm spacer up front.
Hey if someone wants to try it I'd like to see it. But there are a TON of potential issues. And honestly, when you're all done, you may not have a car than handles any better than one with a well tuned torsion bar suspension even if everything works great. Because really, a well tuned torsion bar suspension is no slouch. The current coil over conversions aren't demonstrably better. The Hotchkis Taxi can lap at TireRack's test track faster than the 2012 3-series beemers they use for testing. That's a ton of work to undertake on a "maybe", even if you have all the skills. I do, I have both the skills and equipment to make that happen if I wanted to, and let me tell you I have zero desire to do it. If you spent a fraction of the time and effort needed to complete that swap you could have a very well handling torsion bar suspension car.
Not disagreeing with you at all. I know there is no real difference between 2 or 4dr. I just thought it was odd that the .pdf manual I have listed it as such and was wondering if it was a known mistake in it. No biggie.There's nothing unique about the 4 door suspension.
I know you know your stuff when it comes to making an A-body handle. I've probably read every post you've made covering the topic. The thing I think you're missing is that not everyone is after max performance handling on our A's. Some of us would just like an updated, lighter, more responsive front end that we can buy replacement parts right from our local auto parts store for our weekend cruiser/daily driver. I don't need AutoX performance and wide 275's all the way around nor the ride quality that comes along with it.Hey if someone wants to try it I'd like to see it. But there are a TON of potential issues. And honestly, when you're all done, you may not have a car than handles any better than one with a well tuned torsion bar suspension even if everything works great. Because really, a well tuned torsion bar suspension is no slouch. The current coil over conversions aren't demonstrably better. The Hotchkis Taxi can lap at TireRack's test track faster than the 2012 3-series beemers they use for testing. That's a ton of work to undertake on a "maybe", even if you have all the skills. I do, I have both the skills and equipment to make that happen if I wanted to, and let me tell you I have zero desire to do it. If you spent a fraction of the time and effort needed to complete that swap you could have a very well handling torsion bar suspension car.
Yeah, I snagged that one as well!FYI Furious, here's another pic I got from the net a few years back with some actual measurements taken from a Crown Vic front end.
Right? Like the custom engine mounts, steering shaft, oil pan, headers and chassis reinforcements will be easier to deal with than the bolt pattern.
This is a really interesting thread. I am thinking I like the SC400 maybe better than the CV frontend. For a guy with more time than money this might be the ticket for a lighter weight drag car frontend.
Tom
That narrow CV crossmember is fabricated steel and is $795. If your going that route you might as well just build your own. My idea for wanting to using a Lexus clip is to gain width inside the engine compartment and shedding weight at the same time. After some research using a 92-98 SC300 will give you 10.8" brake rotors and the 92-00 SC400 99 SC300 will give you 11.6" rotors. If you still want more the 95 LS 400 brakes are a direct bolt on with 12.4" rotors and a very nice aluminum 4-piston caliper. Then if your all out road racing the even larger brakes from a Toyota Supra also bolt on. More options for the guy that likes to play around with projects.
Tom
interesting...I own both an SC400 and a 65 A. Word on those Upper and lower control arms...no serviceable ball joints and nothing new is cheap on a Lexus/Supra. And they do handle like a ****..... if you need an SC measurement I can oblige.
