The least expensive way to mount large bolt pattern wheels is with adapters.
They will bump the wheel outward about an inch which shouldn't be a problem.
Adapters got a bad reputation that was due to improper installation. They must sit flat against the hub surface. If a weight on a drum interfears they will get loose. Grinding clearence is the only option.
