Lift Bundle End Supports repurpose thread
Shop, Garage and Tools
  1. Bill Crowell
    Bill Crowell FABO Gold Member FABO Gold Member
    945
    487
    Oct 16, 2007
    Diamond Springs, CA
    Local Time:
    9:42 PM
    When you buy a lift, the seller bundles all the heavy parts up together for shipment by attaching them with 3/4" hardware to some really Hefty & Brawny welded-up steel end supports, which I will call the "LBES" for short (see attached picture). These things are way too nice to throw away.
    I think I am going to use mine to a support a table made of steel plate, to which I can bolt things for welding, bending and straightening. (I need to learn more about building a welding table before I do, though.)
    So what have you done with your LBESs, or what do you suggest doing with them?
    • Like Like x 2
    • 4spdragtop
      4spdragtop FABO Gold Member FABO Gold Member
      29,573
      9896
      Aug 28, 2009
      Wasting time here
      Local Time:
      11:42 PM
      Same with these...heavy duty but no idea what they could be used for?? 10 years of tripping over them.... off to steel bin.
      • Like Like x 1
      • pishta
        pishta I know I'm right....
        18,267
        7741
        Oct 13, 2004
        Tustin, CA
        Local Time:
        9:42 PM
        throw a solid core fire door on top and make a work bench? Couple of diagonals across the back......
        • Like Like x 1
        • Bill Crowell
          945
          487
          Oct 16, 2007
          Diamond Springs, CA
          Local Time:
          9:42 PM
          I don't think they're really tall enough for a work bench, pishta.
        • missing linc
          missing linc Loose nut behind the wheel
          1,928
          2879
          Feb 17, 2019
          Southern Alberta Canada
          Local Time:
          10:42 PM
          I used mine to build a welding cart and an engine cart, just had to buy wheels and use some angle iron I had laying around.
          • Like Like x 1
          • Tooljunkie
            Tooljunkie King of cobble/master of the broken bolt FABO Gold Member
            15,670
            15241
            Jul 22, 2017
            Manitoba
            Local Time:
            11:42 PM
            Mine were bent. Semi was in a collision and load was written off. My hoist came from an auction.
            I think i used a couple of pieces of it to build my rotisserie.
            • Like Like x 1
            • 67dartgtgo
              67dartgtgo FABO Gold Member FABO Gold Member
              1,115
              528
              Nov 9, 2012
              Mass
              Local Time:
              11:42 PM
              I used mine to make a parts cleaner. Threw an abandoned two basin stainless sink on top and casters on the bottom corners with a shelf welded across the bottom. Bam....free parts cleaner.
              • Like Like x 2
              • 67Dart273
                67Dart273 FABO Gold Member FABO Gold Member
                44,989
                12576
                Oct 14, 2010
                Idaho
                Local Time:
                9:42 PM
                How tall are they? Grinder stand? Bench drill press? Can you Weld 'em end to end to get enough height? And sometimes, ya just gotta say "screw it." I've got junk around here I should just give up on and take to scrap., one big piece I had for YEARS . It was an odd construction bench made from a Model T frame that had a large structure, formed the front legs and extended up and back at an angle to form a slanting back, with sorter legs "triangulating" towards the rear. IT WAS AN operations / equipment rack for a 1920's !!!! defunct radio station!!! in my home town. I used it for a work bench got in in 64!!!!! It sat in the shed through my Navy years (68-74) and I finally drug it up to this house in the mid 70's. I FINALLY cut the damn thing up sometime in the 80's and used some of the material "for something else"
                • Like Like x 1
                • 64DartGTinAZ
                  64DartGTinAZ FABO Gold Member FABO Gold Member
                  2,573
                  704
                  Aug 14, 2010
                  Phoenix
                  Local Time:
                  9:42 PM
                  Put casters on them to gain altitude? Bigger casters roll over junk better anyway :)
                  • Like Like x 1
                  • Agree Agree x 1
                  • oldkimmer
                    oldkimmer FABO Gold Member FABO Gold Member
                    16,457
                    4857
                    Nov 11, 2006
                    Kindersley, Saskatchewan,
                    Local Time:
                    11:42 PM
                    Put a V shape on top and use them for building rear ends. Dana, 8 25 etc. Kim
                    • Like Like x 1
                    • 4spdragtop
                      29,573
                      9896
                      Aug 28, 2009
                      Wasting time here
                      Local Time:
                      11:42 PM
                      Neighbor across the road grabbed them lol. He said to chk his front lawn in 10 years.
                    • canary runner
                      canary runner riding in a 66 cuda
                      122
                      10
                      Dec 18, 2011
                      clermont ia
                      Local Time:
                      11:42 PM
                      Nice end pieces... I got some pieces similar to those made out of rectangular steel tubing... at a fabrication truck place i worked at... a heavy piece was shipped to us in this container...I cut the pieces I wanted off of the container & I bought a sheet of 3/8" thick steel for the top... It has a HD and LT Duty bench grinder across from each other ... 6" vice... Cutoff saw...& a short piece of RR rail for really beating on something...Its heavy enough that you CAN'T push it around!!! Just a suggestion.... Never have a heavy enough workbench!!!!
