Lift point for 2 post lift
davecarney2
North Carolina
Anyone know the best/safest placement of the pads for lift points when using a 2 post lift on a 74 Dodge Dart? Picked this up the other day and want to get it up on the lift and go through it.
Make sure to get the on the true subframe, not the floor pan. If you look under the car, you will see where the subframes end & the floor pans attach.
I always used the subbframe directly in front of the front leaf spring mounts for the rear. And the subframe in front of the transmission crossmember for the front.
