A friend was considering bushing his lifter bores to run a solid roller. Do bushed lifter bores require any hole to allow oiling of the roller lifter body? If he wants to convert to solid flat tappet cam later in life does he need to modify the bushed lifter bores beyond what is needed for the roller?
Thank you
Thank you
