DionR
Building an LA/Magnum hybrid Frankenstein motor with an LA block and MP Magnum R/T heads, Hughes retrofit rollers, OEM 5.9 cam and stock Magnum rockers.
Currently I am measuring my lifter preload at .085" with a Ford pushrod measuring 6.88" long.
I know the recommended preload is .020"-.060", and I would prefer to be on the lower side of that, but I need to get my motor together and would prefer to just bolt these up.
To add to the confusion, in the Service Manual, they list a tappet "dry lash" spec for all smallblocks as .060"-.210", and yes they were all hydraulic tappets. Is this an indication that a lifter preload of .085" is ok? Or is "dry lash" refering to something else?
The motor isn't going to run that high in rpm with the stock cam so I don't think lifter pump up will be an issue, but would like to hear some other thoughts on it. Don't want to excede the limits and hurt my lifters either.
I can order some 6.821" pushrods and get my preload down to .026" or so, and I might do that in the future, but I don't really want to wait for them right now.
Thanks.
Thanks.
