Slantsix64
Hey guys I got a question for you! I need to swap out my lifter on my 318, can I leave the intake on, and just remove the lifters with a heavy duty magnet? I know for sure I will soak the new lifter in oil over night.
Thanks for the advice, I'm just tired of that damn lifter chatter lol was hoping could use my magnet to pull them out, make the job a little easier.take it that this is a LA motor not a /6
most likely will not get them out with a magnet
use a puller
now you can soak your lifters but it U do you have to rotate the motor over at least twice stopping every 90 degrees to bled down the lifters
do not do this with tight piston to valve clearance
Best to rotate the oil pump (proper direction) with some hex stock while you rotate the motor quarter turns- and make sure oil is oiling the rockers while you do this
install valve covers and set timing if you took the dist out or timing chain
if you did do the chain make sure your tdc is on the compression stroke not exhaust
or just put them in and let them clatter till they pump up- noisy but hurts nothing
starting a motor with pumped up full of oil lifters can bend things like valves and pushrods
jusk curious, why are we swapping lifters?
do the concave test with a straight edge or put two of the lifters together- they should rock- if they are worn it's time for a new cam and lifters and timing chain
I did it on a 340 with stock heads. Lifter would only fit through the head on the end. Pulled the rockers and push rods, grabbed the lifter with the magnet, drug it down to the end and wiggled it out.Hey guys I got a question for you! I need to swap out my lifter on my 318, can I leave the intake on, and just remove the lifters with a heavy duty magnet? I know for sure I will soak the new lifter in oil over night.
I let the new lifters soak in marvel mystery oil over night, changed oil and filter applied assembly grease on lifters and rockers filled the bowls up and started her up 2500 rpm 15 mins. just used one quart of valvoline race oil with zincGreat. How did you do the break-in?
