phf
i was wondering if its better to go with a roller over a flat tappet on a 400hp 318 build. id use the stock 5.2l magnum roller rockers from the dealer. will the lifters be able to take a thumpr cam?
As long as you have a magnum block or one of the late LA blocks that came with roller lifters you will be OK. Those lifters cab't be used in LA blocks because there is no provisions for attaching the spider that hols those lifters in place.
