MopaR&D
Nerd Member
Can you please explain why a 160* doesn’t allow the engine to run cooler? Seems that opening sooner would give the cooling system a head start to start dissipating the heat...Maybe I just never thought that through the whole way.
Has anyone had experience with the Flow-Cooler water pumps. At the time I bought it they were all the rage.
A lower-temp thermostat increases load on the cooling system because you have less of a temperature differential between the water/coolant in the rad and the outside air. Also your engine puts out a "set" amount of heat so trying to keep the whole system at a lower temperature means it effectively needs to shed heat faster. The only reason to put a lower-temp t-stat in your engine is if it's heavily built and needs to run at a cooler temp for best efficiency, like if you have high compression the lower running temps will reduce detonation.
Regarding electric water pumps, the Roadkill/Engine Masters guys did dyno tests of how much power engine accessories actually draw and it's almost nothing; I think they got less than a 5 HP loss (at the top of the RPM range) going from an externally-powered electric pump to a mechanical water pump with a typical pulley setup (slight overdrive on the pump), they also pointed out that mech pumps almost always have better flow and cool better since they change RPM with the engine. Knowing that, there's almost no reason to run an electric pump at all IMO.
