RobbAdams
I have never raced a car on the strip before, so please bear with my ignorance.
I am putting in a front disk KH Set up in my 66 barracuda, and thought that I might as well put in a Line Lock at the same time for "Track Days" The guy who is doing my brake setup for me asked how I wanted the line lock set up. I have never had on before, so I thought I would gather some opinions. Car is a 360 SB with an auto tranny (Still Debating between the 904 and 727, I have both) the options he gave me included the following:
-a 4X4 type setup that installs a lever/valve next to my seat
-an electronic Type with a button (He says they are not reliable)
-a Line lock that is built into the proportioning Valve that you engage by pressing the brakes all the way to the bottom, and release by tapping on the brake?
Also do you use a line lock that uses the line lock to :
-Lock the front brakes in a Clamped position
-Block the rear Brakes from Engageing, and modulate the front Brakes with the peddle
