Linkage help
Frank Dinatally
Pennsylvania
Hi guys, Hope you all had a great Thanksgiving. I am using the original intake manifold on a 65 273 commando but will be using Edelbrock carburetor. Will I need the 1481 kit to hook it all up.. thanks in advance, Frank
What @MOPAROFFICIAL said.
I just finally got mine set up after a Magnum swap so I have full throttle and the correct throttle pressure (kickdown) adjustment for perfect shifts.
I used the top hole for the throttle cable and added a ball end stud in the bottom hole for the kickdown linkage.
Got a part # for the ball stud?
