I have an old freebie 2 wire distro I want to completely lock out to try with my Fitech EFI unit which has timing control. Do I just need to tack weld the weights at the places I have circled in the picture? Should the weights be in the closed position before welding, or spread open like during full mech advance when welding? And I could probably remove the springs, right?
And no, I don't want to buy the FBO plate or a lean burn distro. I want to lock this one out. Thanks!
