All I have are pics of the carb. end. Do you need a pic of where it hooks to the trans? If so I'll have the Cuda jacked up to do work under it either tomorrow or sat. and can take a pic of that end then.
I can tell you it was the best money I spent on the car lately made a hugh diffrence and works great when properly adjusted.
whos using them can u post some pics thanks
i have been using Lokar kickdown set ups for years. has always worked very well for me..
what pictures do you want of it?
How does the throttle cable hook up to the accelerator pedal? The lokar instructions dosen't cover that.
Bob
Has anybody else had the plastic piece that attaches to the carb break? I don't know if I had it adjusted too tightly or what but out of the whole kit that's the only part that I would call "cheap". I wound up upgrading to the piece you see everyone using on their throttle cable. One thing I do like about the kit is its simplicity. It's so easy to install and adjust, unlike the TV cable on the 2004r I have now.
Anyone have a spare stud that bolts to the carb for the kick down cable?- I'm pretty sure I sent mine with the Holley carb I sold.. (the plastic piece clips to it) OR have the replacement PN?
I found one on Ebay - same stud used on a cheby 700R4 TV cable Thanks though!!I might have one. Will look today and PM you later about it.
