Lokar Parts List
DartGTDan
'71 Dart GT Fan
metro-Detroit
I'm getting my Summit order together for the Lokar products I'll need (as seen on Tony Fields' car (1st photo)).
I have a 1971 Dart GT 318 with the A904 console shifter. I will be putting on an Edelbrock LD4B intake manifold with an Edelbrock 1406 600 cfm carburetor.
Have I selected the correct Lokar parts for my application? Please see 2nd photo.
Yep, as far as the Cables are concerned....not sure on the bracket....i went with the one piece unit.TCB-40DQ.
But mine is on an AFB at the moment.
http://www.summitracing.com/parts/lok-tcb-40dq/overview/
You might be able to save a few bucks with the Duo-Pack that has the throttle cable and throttle bracket and return springs in one kit?
http://www.summitracing.com/parts/lok-dp-1000ht
If you have not used one before, they are nice setup, but pretty generic (not really much that would make them brand specific.) The throttle cable end and bracket that connect the the carb would be the same for any car. The throttle pedal end has an aluminum connector for different throttle pedal setups, for use on the Mopar, you just pull the inner cable out to remove the adaptor, and there is the ball on the end of the cable that you need. Slide the cable back in the outer cover, and connect the carb end connector (has a set screw to hold the cable.) If you get a cable that is too long, it is easy to cut to a shorter length, just make sure you to remove the inner cable before cutting the outer cover. I had to shorten the outer cover on my kickdown because the inner cable did not have the length for full kickdown travel.
The cables are also avaliable in black if you prefer that color, but cost a bit more.
