[WANTED] Long reverse light screws
iw378
Suisun City, Ca
I have the long style reverse lights on my 69 barracuda. I need 2 of the correct screws. They are about 3 inches long P.O used sheetrock screws.
Luke
i would take one of the ones you have down to fastenal. They can get them for you even if you need to buy a box of them it is still likely cheaper then buying and shipping a pair. They aren't anything special.
Still looking for some reverse light screws I have the long reverse lights. Also looking for a set of headlight bezel screws for a 69 barracuda. I think there is 2 about 2 inches long and 2 that are like an inch and a half long. Also looking for plastic wiring connector that goes on the end of the turn signal wiring coming out of the column
My original screws were long gone and replaced by oversized wood screws or the like. I bought a nutsert kit, which works like a rivet gun and secures a threaded insert. I am going to drill out the holes, add the nutserts, and use the correct size machine screws.
Luke
Home Depot, #10x 2' stainless sheet metal if I remember right on the length, about $1.25. I just did the ones on the my car. Get the tapered head Phillips.
If you just have to have the correct screws you could try mrgusa.com catalog.
I think correct is a chromed oval head Phillips. I don't know the correct length for a 69.
As for the nutserts mentioned. Ford used those things in the truck door skin to attach their trailer mirrors. For the pre-delivery guy, nothing else could ruin a good day so quick or often.
I have the Long lights. Gotta be 3 inch screws. I'll look this weekend
Found some. For those that care or need some I happened on them by accident. My neighbor has a 67 camaro rs/ss. She was missing a vent window screw and did not know what to get.
I pulled the one she had out and it was what I needed. heartbeat city has the screws in pairs.
I ordered 2 pair for me and 1 pair for her.
Luke
