Is there an up side to running a slightly longer valve? As in .040 longer. Is there a down side? Does rocker geometry go all to hell? Thanks. Kim
Lots of people run screwed up rocker geometry, even some of the well known shops. Youd be surprised.
Lemme answer the question directly. You can install a .040" longer valve and make things worse. You can install a .040" longer valve and make things better. It depends upon the application. You have to be smarter than your cylinder heads.Is there an up side to running a slightly longer valve? As in .040 longer. Is there a down side? Does rocker geometry go all to hell? Thanks. Kim
They can but cut to a point, till they allow aluminum rocker body contact on each side of the roller tip with the retainer...Thanks guys. I was thinking that the tip could be shortened if need be. Also I see the installed spring height will be different by that amount. Kim
I have before. That would about max unless the lock groove is lowered or you have a very flat retainer.The valve is supposed to be 5.011. The ones I got are 5.040. .029 though taller. These are the intakes. The ex valves are 5.011. Do u really think there will be a problem taking .029 thou off the top? I do realize that the intake springs will be that much higher. So maybe the spring or retainer will hit the rocker. I’ll see what my head guys says when he sees them. Kim.
