Gator77
I have a 75 duster with a 26 in radiator support .looking for a good aluminum radiator part number .and where to buy thanks for info.
I have had really good results from Griffin radiators using a belt driven 7 blade fan, 160 degree stat ,thru SummitI have a 75 duster with a 26 in radiator support .looking for a good aluminum radiator part number .and where to buy thanks for info.
I see this going 45 posts or more.
Cross flow or down flow? Type of coolant? Stat or no Stat? Fixed fan? Clutch fan? Or electric? All things we need to know to make a honest recommendation. Let the party begin.
I `ve got quite a bit more h.p. than u, and run a 28x19 griffin crossflow. I highly recommend them, I was pulling my car around on a floor jack, and it slipped off the jack and bent the griffin up about an 1 12'' IN THE CENTER/ALONG WITH THE FRONT SPLASH PAN AND LOWER FRONT CRADLE. I STRAIGHTENED AND REPAINTED THE BODY PARTS, AND DID NOTHING TO THE RAD. AND IT`S WORKING FINE. HAVE THE PICS ON MY PHONE FOR PROOF. No epoxy in them all alum welded .----------- disregard caps as always----------I have had really good results from Griffin radiators using a belt driven 7 blade fan, 160 degree stat ,thru Summit
That's nasty.I `ve got quite a bit more h.p. than u, and run a 28x19 griffin crossflow. I highly recommend them, I was pulling my car around on a floor jack, and it slipped off the jack and bent the griffin up about an 1 12'' IN THE CENTER/ALONG WITH THE FRONT SPLASH PAN AND LOWER FRONT CRADLE. I STRAIGHTENED AND REPAINTED THE BODY PARTS, AND DID NOTHING TO THE RAD. AND IT`S WORKING FINE. HAVE THE PICS ON MY PHONE FOR PROOF. No epoxy in them all alum welded .----------- disregard caps as always----------
LOL, agreed !That's nasty.
I would not give up your day job to become a NASCAR jack man. LOL
