stingerdart1972
Looking for help to steer me in the right direction toward a LA 408 stroker motor, for my 72 swinger with a 833 close ratio 4 speed setup.....
Looking for a LA 408 Stroker crate motor built for a 4 speed that will put a huge satisfying smile on my face. From a FABO recommended builder that Ships to 02660 in Massachusetts.
I don't believe the 2 local machine shops in my area have the MOPAR build experience after under the radar chatting with both shops " more ford and chevy" .... besides that the pickings for a good core 360 motor is slim to none...
What's in the Car now...i have a peppy but tired LA 318 with MSD rev box, MSD electronic Distributor and Coil, LA Eddy 6077 aluminum heads, LA Eddy Air gap manifold, Thumper Cam, Roller Rockers, Comp Cam push rods, Proform 650 Carb and Dougs Ceramic Headers.
SIDE NOTE: after the said fact the guy that put the parts on my motor informed me a couple of months later that the spring heights on the Eddy heads were all off.. so somewhere down the road a machine shop will need to address this if and when I reuse these.
Centerforce flywheel, street/strip pressure plate and disc.
A-833 close ratio 4 speed
489 sure grip with 3.55 gear
And pitiful 14 inch stock small bolt rally wheels ... I need a 15 wheel I realize this...
All my reading and looking around the $6000 ish Motor builds have number range:
400+ HP
450+ TQ
is there a long block LA 408 stroker motor available " I can re use the MSD electronic Ignition and distributor and Air Gap intake manifold and get a bigger recommended Carburetor"
or is there a drop in LA 408 stroker crate motor/with Aluminum heads, 10to1 that runs on pump gas, built with the best Cam/lifter/rocker combo set up for a 4-speed with 3.55 gear...
Must be a ground pounder with nasty idle that turns heads..
It's not a daily driver so MPG is not important as it's driven on weekends to the local car shows and to the coffee shop... neck snapping shoved in the seat and tire burning and evil laugh is a must !!!
Thanks Kevin
400+ HP
450+ TQ
Thanks Kevin
