Shane
And this time I am going to do it right. With pictures and questions/help along the way...
As some have read, I am having an issue with the 69 340 in my barracuda convertible...still going to pull the pan to make make make sure , but its got a bad rattle to it...
Anyways, I have had this block, and these heads kicking around since I got the car(they came with it) and I think its time to figure out what stroker kit to buy, and find out with help from you guys the best way to build it to make a fantastic street motor...
What I believe I have is a 76' 360 block, that appears to be in good shape. (from my limited knowledge)
And 71' X heads...
So what I am intially thinking is to bore it .30 over, buy a stroker kit (suggested by people hear with knowledge) , get the heads done and go from there... Also need suggestions on what cam to run... I am thinking a solid lifter cam(will that work good? or go roller?) these are things I need help with...
Here are the pictures of what I am startin with...
And 71' X heads...
