SRT_DSTRHOLC
What's a good all around welder? I want to be able to weld cages and stuff so max 3/8. I'm looking at millers new 211 mig, I want something that will do it all for around 1300 or under.
bought a Miller 211 a few years ago....great welder...110 or 220....autoset easy welding...can use flux wire if you want..
What cage uses .075 material?
Doesnt NHRA have a requirement that cages be tig'd?
Tweco 211i or Lincoln 210MP. Both about 1000'ish, both dual voltage, both can also do SMAW and lift TIG-DC. The Tweco can run 12" spools, the Lincoln only fits 8" IIRC.
http://www.weldingsuppliesfromioc.c...g-tig-stick-welder-pkg-w1004201-with-w4014603
$1100 with the TIG gear.
Tweco used to be Thermal Dynamics. I had a 181i but sold it to upgrade to a dual voltage 211i for the house. Both it and the Lincoln are inverters. S/F....Ken M
That 211i, how thick can you go with it mig and tig? I know the house should be setup for 220v so either way I will have to get a separate plug only for 230 or 240
