I'm swapping my rear end to a 8 3/4 - 741 - 3.23 open diff. I'd like to swap out the open diff before i install the new rear axle. Ive done searches here and turned out a bit confused. Sure grips, true tracs, powertrax, lockers, slip diff, clutch, cone, etc. Lots of options!
It seems like the sure grip is the way to go from what Im reading. It's for a Duster who mostly stays on the street and has a mild smallblock. I will take it to the strip occasionally and want to have good traction and Id like it to draw two black lines if I feel like it  Any suggestions on what to get? Links will be appreciated.
