easyrider
65 droptop
So what is a tone ring on a 2002 5.9 Magnum engine and how does it work? Do you still need it if you remove the EFI and use a carb?
Tom
Tom
Tom
OK, I bought the engine today. It is complete including the accessories. P/S, A/C comp, Alt with belt still on it. Engine has 40K on it. I was thinking of stripping the EFI and running a carb, but after measuring it I think I want the EFI. I didn't think I had the clearance. I'm going to run my 904 so I think I'll need a different ECU. Will I need the one for a manual trans since the 904 has nothing to communicate to the computer?
Tom
