SuperStock
I did a lot research, if I swap the Front Carrier, Front Ring Gear, Sun Gear from A999 to 904 I will have lower Gear Ratio on both 1st and 2nd Gear, the ratio will be 2.74/1.54/1 (904 stock ratio: 2.45/1.45/1)
I dont want lower on both 1st and 2nd Shift, I want lower ratio at 1st Gear only, like: 2.74/1.45/1
After study the 904, I release that if I want to lower the 1st Gear ratio, I will need bigger Rear Ring Gear and/or smaller Sun Gear. Are there aftermaket set that lower 1st Gear ratio only? Or anyone have modify 904 this way please let me know how did you do that?
I always think instead of Lower Axle Gear to help the car launch faster, Lower the 1st Trans Gear will do better job, what yours think?
