74 Duster, Big Bolt pattern, Small block,1 1/8 sway bars front, Firm Upper Tubular A, QA1 adjustable strut rods. Ok that covers that I hope.
How does the plate welded onto the bottom of the Lower Control Arm effect binding at the Torsion Bar Socket end?
About to weld these plates on looks like it would take some of the adjustability out of that end.
If you Adjust the strut rod is the location of some of the movement at the control/torsion socket end?
Thanks
Thanks
