Randy WM, it depends on what you are replacing as to how you do this. If you are replacing the bushing with an OE rubber style then the sleeve and the bushing must be removed. If you are going to use the polyurethane bushings then the sleeve needs to stay in the LCA. To remove the bushing and sleeve, you can pry out the bushing with a screwdriver, then tack weld a washer to the lip of the bushing and press out the bushing using the washer. Just be careful tacking on the washer. You can also use the tried and true method of using a chisel to score the side of the bushing and then folding it in on itself and using a pair of needlenosed pliers to pull it out. Just be careful to not score the LCA with the chisel. Either way needs to have a little patience applied before diving in. Take your time and be careful, you'll be glad you did. Good luck with your project, geof
