boilermaker
Hi ,
Got a 75,000 225 slant in a 68 rag Dart GT.
Replaced all rad hoses this year and all was good.
Car has 3:21 gears and 26" tire so 3200 rpm keeps up on the highway.
I have found the car gets hotter the more rpm. 160 deg thermostat and new rad cap. The new lower rad hose came without spring so I installed.
After a 100 miles found the hose collapsing at higher rpm.
Installed new spring in lower hose and now car is running even hotter (190-200).
Should I install a lower rad hose restrictor (I know the thermostat is some what of a restrictor).
Just thinking that the collapsing hose allowed the water to have a larger "delta T" at the rad.
Also any thoughts on slowing down (larger pulley) the water pump to assist in the cooling at the higher rpm.
Thanks in advance.
Thanks in advance.
