Dan the man
Just a question, I'm trying to learn about cams. If a 108* lsa is good for torque, then how can a cam that has a 112* lsa said to have strong torque? Is it the duration at 0.050 "? Again, just a question. Thanks
K. Thanks. Do you suggest any certain articles about cams?That question is much to broad to have an answer that would satisfy all criteria.
It's combo dependent, doesn't mean 108 gonna make more low end torque than 112 in every application.Just a question, I'm trying to learn about cams. If a 108* lsa is good for torque, then how can a cam that has a 112* lsa said to have strong torque? Is it the duration at 0.050 "? Again, just a question. Thanks
That's actually a very good question. Think about IVC and its effect on cylinder pressure.Just a question, I'm trying to learn about cams. If a 108* lsa is good for torque, then how can a cam that has a 112* lsa said to have strong torque? Is it the duration at 0.050 "? Again, just a question. Thanks
Yes, any and all articles you can find. There are also many books written on the subject and that’s where you should start.K. Thanks. Do you suggest any certain articles about cams?
Remember that LSA is a product of the other specs, not a defining spec itself. Changing LSA means changing when all valve events occur.And don’t forget, you can’t change the LSA of a cam in isolation.
David Vizard’s YouTube channel or any of his books.K. Thanks. Do you suggest any certain articles about cams?
K. Thanks everyone for your helpDavid Vizard’s YouTube channel or any of his books.
A cam upgrade from stock is still a good idea. The factory cam balances a bunch of considerations, having nothing to do with good power and torque production.My intended goal is to have good throttle response and low to midrange torque. As some have said that I maybe satisfied with the way it already is and if so then I'll concentrate on the tuning of the ignition and carburetor. I'm looking forward to the learning curve
I've started to read about camshaft timing events. Would a cam that has a 108* lsa and duration of 204* / 214* @ 0.0.050 " have a rough idle?
That really depends on a bunch of things, off the top of my head, 3 big ones are,I've started to read about camshaft timing events. Would a cam that has a 108* lsa and duration of 204* / 214* @ 0.0.050 " have a rough idle?
What your kind of talking about with rough idle is overlap when both valves are open, bigger the overlap the less it likes to operate at very low rpms. So a 108 204/214 will have more overlap than a 113 204/214 but will have same as a 113 214/224 which would be on the mild side still.I've started to read about camshaft timing events. Would a cam that has a 108* lsa and duration of 204* / 214* @ 0.0.050 " have a rough idle?
Get yourself a copy of the power pro series how to build and modify Chevrolet small block V8 camshafts and valve trains. You'll be a cam pro. Chevy, but info is across the boardJust a question, I'm trying to learn about cams. If a 108* lsa is good for torque, then how can a cam that has a 112* lsa said to have strong torque? Is it the duration at 0.050 "? Again, just a question. Thanks
