VF69HARDTOP
Hi guys
I'm looking to fit a Lunati 30200741 solid flat tappet cam in my 360 and wanted to know if any has one fitted and if it has sufficient idle vacuum for power brakes.
Solid Flat Tappet. High performance street/mild bracket cam with good mid range to high end torque and HP. Needs 3000 RPM stall converter, headers, 10.5:1+ compression, 3.73-3.90 gearing. Lopey idle. ;Advertised Duration (Int/Exh): 272/280 ;Duration @ .050 (Int/Exh): 243/251 ;Gross Valve Lift (Int/Exh): .546/.566 ;LSA/ICL: 110/106 ;Valve Lash (Int/Exh): .016/.016 ;RPM Range: 2600-6800
Thanks
Thanks
