VF69HARDTOP
Hi guys
Im slowly piecing together the parts for the engine while Im working on the body to send it off to the painters.
Im after some advise on the following two Lunati Voodoo cams, 10200703 and 30200740. I know the later is step up but it only requires near the same supporting upgrades and around the same stall speed and I don't want to run a larger stall than 2500rpm. Seeing as I need to fit the correct 73949 valve springs for either cam, I need to upgrade the rockers so Im looking at getting Hughes roller rockers.
Due to needing to run roller rockers, a few people are suggesting I just run a solid flat tappet cam while Im at it. So, my question is, will the 30200740 solid be too large for the following 318 engine spec or should I stay with the 10200703? I want to make some grunt with it but also want it to be streetable and not carry on like a stuck pig.
318 + 0.30" oversize KB 167
10:1 comp
Alloy heads with 2.02/1.60 valves (Aeroflow, Aussie brand with Eddies specs)
RPM air gap inlet
Good headers
Pertronix Ignitor III billet dizzy with matching coil
Carb/FITECH not decided but leaning towards the EFI
2500rpm stall max in a 904
I have either 3.45 or 3.9 gears sitting here, happy to use either
The car is not a daily driver and won't be covering long highway stretches. More used for a cruise around town with a trip to the qtr mile every now and then. Its going in our Aussie version of your 69 Dodge Dart.
Thanks in advance for any feedback.
10:1 comp
RPM air gap inlet
Good headers
