Anybody running one of these ? Thought about one for my daily driver for better low end power and fuel mileage. Its a 69 dart with a 273 auto,2.76 gears currently running a 66 commando 4bbl intake and a 500 holley carb.
Here is a link http://www.lunatipower.com/Product.aspx?id=2459&gid=294
Cam Specs:
Hydraulic, smooth idle. Good cam for daily usage with good low-end torque and horsepower.
Advertised Duration (Int/Exh): 260/260
Duration @ .050 (Int/Exh): 210/210
Gross Valve Lift (Int/Exh): .441/.441
LSA/ICL: 110/106
Valve Lash (Int/Exh): Hyd/Hyd
RPM Range: 1000-4500
Cam Specs:
LSA/ICL: 110/106
