[SOLD] Lunati Hyd. bracket master cam
rumblefish360
I have escaped the EVIL Empire State!
Florida
I was told it was Lunati Bracket Master cam for a small block and I looked up the numbers. There is a 2 stamped on the cam and a 1 in the on line catalog.
It otherwise seems to be in the brand new condition I told it was with the parkerizing still on the lobes. The cam was installed and never fired. Since it was installed, final cleaning, in and outside of the cam is on you.
This is a brand new cam.
Ill 48 state ship this cam and lifters for $160
A few more shots of the cam lobe and parkerizing.
Lubed with the shown can and mummified wrapped up in press and seal.
Interested if it fits a stock 273. Go easy on me, I’m new at this.
This cam is not for you. Sorry my man. This is not a stock camshaft nor is it, “On the Brink” of being too much ch for a 273.
It is on the verge of being ridiculous to much unless you have some decent gear and a high stall converter behind it. Even though it has a listed power band of 2-5K, it’s the 273 is very small and makes a low amount of torque. Unless you have amped the engine up quite considerably, this cam will make the engine a total dog with out power way beyond the listed and early 2K power band starting point.
It seems like your looking for a stock or close as possible replacement cam for your 273. Look at duration @.050 numbers in and around 195 - 205 for a suitable replacement cam. A 4bbl. cam can go another day 6-8*’s @.050 & still work with a low gear set and stock converter. I would not personally go any higher in cam duration.
Thanks, I appreciate the interest.
