xmerlinx
Regards and God Bless
Would a Lunati Voodoo 10230703LUN (Formally 60303) be too much for a stock 383? I already own it.
SPECS: Hydraulic Flat Tappet. TDuration @ .050 (Int/Exh): 226/234; Gross Valve Lift (Int/Exh): .494/.513; LSA/ICL: 110/106; Valve Lash (Int/Exh): Hyd/Hyd; RPM Range: 1800-6200
It’s going in a 73 Duster with a 3.91 and automatic. I have a performer RPM, Schumacher headers, mounts and 440 source stealth heads. The 383 came out of a low-mile Dodge Monaco 2 door. It’s an old project I’m trying to revive… Not trying to race it.
I did research, but results are all over the map. I thought one of you folks may have first hand experience?
Any advice is appreciated.. Thanks!
