streetdak
I want to take the master cylinder from my 92 Dakota and put it on my 73 Dart. My Dart is a front disc power brake car and the stock master cylinder is leaking. If I change to the master cylinder off of my dakota (lightweight aluminum 2 bolts) I know I will need to get the adapter (unless the dakota booster is a bold on which i doubt). But now my question is do i HAVE to change to a manual brake setup or will that adapter just bolt directly to my 73 brake booster?
If indeed i do have to change to manual, some people are claiming that the stock pushrod will work for power brakes and some people disagree, any clearance to this?
