sheetmetaldan
Thanks
No problem glad to help. I didn`t have a big enough drill bit so I went as big as I could and used a dremel to make the hole bigger. Sort of a PIA but I got it to go. You may want to have a machine shop drill it and avoid the hassle I went through.
This grommet kit comes with a rubber plug too. I cut the bottom off and it fit the other side where the twist on style breather would go, fit perfect and I was able to use my factory push in style breather. I`ll post a pic of my setup.
