The Holley Strip Dominator was, well, kind of copied my MoPar. You can't miss it in a side by side look. The MP unit is slightly taller.
The problem with the MP unit is it has a spreadbore design carb pad. The idea was for it to be accepting a TQ for super stock and other catogoreies that demand the stock carb be used. This is a problem for flow in square bore carbs.
The Victor is also a good choice, but not listed. I eflt it had more top end RPM power than the others listed. Though IIRC, the Holey was listed as a 7000 or 7500 RPM intake.
The Torker II is a decent intake if your "On the cheap" and/or have hood clearance issues.
