Does anyone know how much machine is required to put a solid roller cam into a 48 degree R3 block? I have seen pictures of the 59 degree R3 blocks which require quite a bit of machining to get the clearance needed for the guide bars. I have not seen or heard anything about the 48 degree blocks.
Aside from the cam cores for use in a 48 degree block, are there any other special requirements or differences to using a 48 degree block?
Thank you
Thank you
