MAD bypass
Snake
Mopar Nut
Belleville Canada
Thinking about the Mad bypass,so lets see if i have it right, so hear goes. i remove the red and black wire at the bulkhead, run a 8 gauge wire from alt join the red and black together then remove the red and black at the ammeter join the done am i right. thanks
"Not exactly." The bulkhead connector still has to feed power to the interior so you MUST fix those terminals in the connector, or else remove the terminals, drill out (enlarge) the connector body out and run wire straight through the connector.
The easy way is with crackedbacks bypass wire which runs from alternator to battery, but again, you still have to have good terminals in the bulkhead connector
dang it lol thanks 67DART273 any chance you or someone can post a diagram what i need to do.
