[WANTED] Mag wheel washers
mbaird
mbaird
Boise, Id
I'm running vintage Dragmaster Slots and they use lugnut washers that are
1.05 O.D. X .90 I.D
The local tire shops don't seem to be able to find these. All of there's are larger O.Ds
I need about 40 of them.
Any ideas?
these are the ones that are oval and seat into a bevel in the wheel? or just a plain ole lug washer?
just round flat hardened washers..
All the ones I have found so far are 1.10+ O.D
................1.05 O.D. X .90 I.D.......QUOTE]
Are you sure about those dimensions?
.075" per side is more off a ring not a washer I think.
Old Cragar SS lug washers for 7/16" are 1" OD .600" ID X .125" thick.
Cragar # 09005-4 is the nut kit they come with if it helps.
yep...I measured one of the old ones .
The Lugnuts have .80 barrels .
There is probably a few thousenths leaway
but not much.
