moper
I stumbled over a '94 Magnum 5.2L out of a Ram. It's essentially free and is totally complete. So I'm wondering a couple things:
First, the timing cover - Will a 273 timing cover fit the Magnum? I understand I'll have to remark the dampner. I want the 273 look and V belt accessories.
Second - will the exh manifolds work? They are the larger outlet Magnums. I thought it was the 93-95 that fit and had the larger outlets but I'm not certain.
Last - does the 273/318 LA oil pan bolt on?
Thanks guys!
Thanks guys!
