alyahyamo
New Member
Project : 2003 durango 5.9 360 v8, pistons and rings replacement
Bought new STD size pistons and rings as cylinders walls looks super clean and shouldn't need boring
However 1st ring gap measures 0.023-0.025
Recommended is 0.020 MAX as per manual for 1st ring
Which means 0.003 - 0.005 more in 1st rings gaps due to high mileage wear
The question is :
Can I still run these new rings with these gaps measures ?
Or should I consider oversizing them to maintain recommended gaps?
The car is for daily driving
The question is :
