sledger46
The heads arrived yesterday afternoon. They were well packed and this is what they looked like coming out of the box.
Here is the combustion chamber:
Here is the intake side:
Here is the exhaust side:
Here are the Hughes hydrualic roller lifters for the LA block:
With a little luck this weekend, I may be able to get the camshaft degreed and start figuring out push rod lengths. It should be fun with a non-adjustable rocker and hydraulic lifters to figure out pushrod lengths and piston to valve clearance. I guess I need a solid roller lifter to get PTV clearance close. On Ferds you can take the roller lifters apart and flip the insides to create a solid. I don't even want to attempt that with the Hughes lifters. Has any converted a Magnum hydrailic roller lifter to solid? What is involved?
![EQhead01.jpg](https://lh6.googleusercontent.com/-pdcqoy2fsCc/UVWm7o8KomI/AAAAAAAADlI/y7kXHwcoiPY/s640/EQhead01.jpg)
![EQhead02.jpg](https://lh6.googleusercontent.com/-TR48Y5VFQdE/UVWm7qciTRI/AAAAAAAADlQ/Hy8f-8m2sXw/s640/EQhead02.jpg)
![EQhead03.jpg](https://lh6.googleusercontent.com/-bSppxa3rE4g/UVWm7-Ht5ZI/AAAAAAAADlY/8DqmgjJukKs/s640/EQhead03.jpg)
![EQhead04.jpg](https://lh6.googleusercontent.com/-zPELlnXSbGA/UVWm8P_wP4I/AAAAAAAADlg/Ijzso2dPNdY/s640/EQhead04.jpg)
![rollerlifter01.jpg](https://lh5.googleusercontent.com/-zXDJH3FjiL0/UVWm8RAmxnI/AAAAAAAADlo/W_87hkWPkMg/s640/rollerlifter01.jpg)
