What is the correct PCV grommet for above? The one I have keeps coming loose. Thanks
Thanks, the lip looks thin like for a stamped steel valve cover. The cast one is 1/2" thick where the grommet goes. Thanks again I found this one Beck/Arnley P/N 039-6506 it is supposed to be for the cast aluminum rocker covers.
No problem, thanks for the input..I entirely missed the aluminum part of this equation lol
I was planning to pick up a set from Mancini Racing but have not done so yet. They off part number MRE5249642 to replace the Mopar version that no longer comes with new valve covers.
I am not sure if the Mopar part number is still available. Shows out of stock or not available at several big vendors. I suspect that is why Mancini Racing has theirs available now, and it looks like they used a similar part number on purpose so it comes up when searching for the Mopar number.
Please post up when you get it. The only ones I've been able to find for my custom MPs and Magnums that have a thick enough channel to fit are accompanied by a plug and cost almost $20 with shipping.
Just get one, for any old mopar, the rubber grommet kit you just got is the same set up that I have.
Yes, shipping is always higher than I expect and annoying. In my opinion, it’s a hindrance to me pressing “buy it now” button at Mancini.
Other than that, there excellent.
