[FOR SALE] Magnum Exhaust Manifolds
Commando66
She's a beaut Clark!
Mount Vernon, WA
Rating - 93.3%
14   1   0
53009376 and 53009377 manifolds with the 2 1/8" outlets. No cracks, but the air port bolts are broken. $50+ shipping. Located in Gig Harbor, Washington.
FYI, those are Jeep Manifolds. The passenger will work on a Mopar but the driver's side is designed for clearance with the starter on the passenger's side of the engine (like on 96/97/98 Jeep 360). Jeeps came from the factory with the starter on the passenger's side of the block, for this reason the driver's side manifold turns in towards the engine where the Mopar starter normally sits.
GLWS
Treblig
Thanks for the info. As advertised, they came off of a 90's Magnum engine. Are you a buyer?
No but your asking price is reasonable and the broken bolts should be easy to fix, I've done it many times. The passenger's side manifold is very desirable for Mopars and if someone has a Jeep motor it a really good deal!!
Treblig
Is the pass side different than a Dakota?
I have some Dak manifolds and the exit is awfully close to the trans dipstick.
If you're asking me....the Dakota manifold will also work on the passenger's side but it exits much closer to the firewall on an A body than the 96/97/98 Jeep Grand Cherokee passenger's manifold.
Treblig
