Magnum heads convert to sbc rockers?
You'll need to use a 1.65 ratio rocker to compensate for the loss of lift when using the Chevy rockers. The PRW rockers that Hughes sells for the Magnum engines are the 1.65.
Curious if the 1.65 SBC rocker gets the ratio back to the factory 1.6 rocker ratio?
